I have the 'store ratings in the music file' ticked, and yet if I make changes to the ratings in MB, the rating does not show in Tag & Rename, which I have been using to work with tags in my library.
My entire music library is stored on my local system in .flac format.
If I make changes to ratings in T&R, then do a re-scan in MB, the changes are updated in MB, but not the other way around.
As a matter of fact, if I change the ratings in MB, the rating in T&R disappears, leaving the track with no rating.
This behavior appears to affect only the ratings tag, as I can change other tags (such as title) in MB, and the changes will reflect in T&R.
I will do some more digging and see what I can find, but in the meantime, has anyone had this experience when using MB and another app for tagging flac files?
Thanks for your help
Ultrarunner
