Author Topic: Relink Music File Paths Error  (Read 970 times)
SpirosG
Hi, when i try to relink music file paths an error occurs.
Tried it on both 3.4 and 3.5 latest patches.
I am on Windows 11.
MusicBee v3.4.8102.36706D  (Win10.0), 18 Μαρ 2022 21:58:
System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
   at System.Collections.Generic.HashSet`1.SetCapacity(Int32 newSize, Boolean forceNewHashCodes)
   at System.Collections.Generic.HashSet`1.IncreaseCapacity()
   at System.Collections.Generic.HashSet`1.AddIfNotPresent(T value)
   at #=zqaGfHv1UdW1Cy_Siv64ATJwWL7qNIy7LxQ==.#=qFuJBqI88taVQhn7_i0wtu6jZwObt5Br212znwV2S4to=._Lambda$__0(IEnumerable`1 #=zfHnPM9c=)
   at #=zBSxDJoU7tmBDA$BqW1bXok4=.#=zXZZl3LlC$7_0.#=z5RE_uBG1rrtJ(#=zctXT2Nrh6Or1Hf2JitIXVcDNHxZ2 #=zPkVa_jQ=)
   at #=zqaGfHv1UdW1Cy_Siv64ATJwWL7qNIy7LxQ==.#=z_oCNvrhY9RtY()
   at #=zqaGfHv1UdW1Cy_Siv64ATJwWL7qNIy7LxQ==..ctor()
   at #=zZayNzbiQusTiMxpjyrnkLWekJYSH.#=zQzu2oRaG4SA_.#=zGZZhN4IJaoFONfC8yQ==(Object #=z9pmUD50=, EventArgs #=z$DSzwsc=)
if you are getting frequent out of memory errors then see:
https://getmusicbee.com/forum/index.php?topic=22778.0
also if you are running the UpnP plugin then that can cause this issue. Also older versions of the VST plugin, so update if using that.
SpirosG
Hi Steven.
Thanks for the help, the solution you have suggested above solves all the memory errors i was getting.
Probably the huge library that i have is the guilty here.
Thanks again.
I don't think so.
Just how large is your collection?
Tracks, albums, total file size.
There are reports of users with over 700,000 tracks and using 5gb not having any issues. Someone else with over a million tracks using almost 15,000gb.
SpirosG
I don't think so.
1.6 million tracks, 302.104 albums, 22TB  :)
Mix of mp3s, Flacs and WAVs
Last Edit: March 19, 2022, 08:09:02 PM by SpirosG
Yup, that's a large collection!
