Author Topic: Custom search (CTRL+F) is occurring an unexpected error.  (Read 485 times)
SpirosG
Hi, using CTRL+F or selecting "custom search" on search window is occurring an error.
Although it shows windows 10, i am on Windows 11.
MusicBee v3.5.8109.36974D  (Win10.0), 16 Μαρ 2022 20:32:
System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
   at System.String.InternalSubString(Int32 startIndex, Int32 length)
   at System.String.Substring(Int32 startIndex, Int32 length)
   at #=zkdP3G8$noHU_PwIMCA==.#=zhAuPIylNLLKd()
   at #=zmDgLaRRimaMGg89rqGMdtMw=.#=z8bBJLfqi7nL9(TagCode #=zwmewWeE=)
   at #=zwUYCUqthGldTPJXw2sW_4V4=.#=z4TIIKEVSLguD.#=z$EKsGhcbTWAf(TagCode #=zwmewWeE=)
   at #=zDGNOexcDpjoYOeLVg07YGjB855r4.#=zOSOig0JY0kTM(#=zoJ0yWtQrrsqUVVkW3Y$mnHQ= #=zE1yvnTBNSI7Z, TagCode #=zZp5WQoM=, Boolean #=zqQLF3pdffts7a0iydA==)
   at #=zDGNOexcDpjoYOeLVg07YGjB855r4.#=zfs78Hapf3PD$(Object #=z8$17Gtg=, EventArgs #=zAZwhYaw=)
   at #=zD86Dk$5Wzgi0tYCXC1xZECs_jhGL.#=z4Ivcuds903YE()
   at #=zD86Dk$5Wzgi0tYCXC1xZECs_jhGL.#=zVPiETxgR8BFJ(Int32 #=zE1X3rmc=)
   at #=zDGNOexcDpjoYOeLVg07YGjB855r4.#=zZtPPgxKqtpW_Xz44iLLY0sw=(#=zq$PM9jCuFKb0I673zNN2zB8= #=zF$0nbmg=)
   at #=zDGNOexcDpjoYOeLVg07YGjB855r4.#=z2pU3udU=(#=zq$PM9jCuFKb0I673zNN2zB8= #=zF$0nbmg=, String #=ztgHuSmmDh4yM, Boolean #=zafzNqp5QnrbA, #=zxB5ptea$s4PYDzoJCldmSeM= #=zvYxdkhSCuWxoadAD_w==)
   at #=zukxFUmX901p9Lu_2xFWgs2g=.#=z2pU3udU=(#=zq$PM9jCuFKb0I673zNN2zB8= #=zF$0nbmg=, String #=zbsO9s8A=, String #=ztgHuSmmDh4yM, Boolean #=zafzNqp5QnrbA, #=zxB5ptea$s4PYDzoJCldmSeM= #=zvYxdkhSCuWxoadAD_w==)
   at #=zEeK26oR4zfQMxepGtMDwcHF9yuH3.#=zhObgsasl28_6()
   at #=zEeK26oR4zfQMxepGtMDwcHF9yuH3.#=ze7iYb3B_Lh6z.#=z$EDtszTKpmFxmmJ4Ng==(Object #=z8$17Gtg=, EventArgs #=zAZwhYaw=)
SpirosG
Solution on the link posted by Steven.
if you are getting frequent out of memory errors then see:
https://getmusicbee.com/forum/index.php?topic=22778.0
also if you are running the UpnP plugin then that can cause this issue. Also older versions of the VST plugin, so update if using that.
