Author Topic: Broken UI when i try to create an external playlist  (Read 506 times)
SpirosG
Hi, the UI is broken whenever i try to export an external playlist.
Windows 11, Musicbee 3.5 (the same happens with 3.4)
What steps are you taking to export the playlist?
What playlist format are you exporting to?
Does this happen with all playlists or just a specific one?
If specific, does it happen every time you try to export it?
Check out the MusicBee Wiki.
SpirosG
MusicBee v3.5.8109.36974D,  Win11, Installer.
Selecting random tracks in library, right click, add to playlist, external playlist. The same happens if i choose to export any playlist within the playlist tree-view.
As you can see, I can't choose the format, there is no option, but i believe it's m3u.
All.  :)
Thanks for the additional information.
You can't select a format from the window showing in your screenshot. To select the exported playlist format: Preferences > Library > playlists > exported playlists > use the dropdown to try with different formats.
This seems like a windows 11 bug. That dialog is a standard windows file save dialog.
I dont have windows 11 myself at the moment to see what is going on.
Make sure the "exported playlists" path in the Library preferences is a valid folder. The path used can be relative to where your library is located
Last Edit: March 17, 2022, 09:56:01 AM by Steven
SpirosG
Thank you for the help.
Unfortanatelly, i've tried all the formats but there was no change.
Hi Steven.
You are probably correct, It seems like a Windows 11 bug, as long as i remember, i didn't face this problem while i was using Windows 10.
The export path is a valid one.
Just tested on Windows 10.
It work just fine.
Last Edit: March 17, 2022, 01:34:18 PM by SpirosG
