Author Topic: Customize fields in Tag Editor  (Read 688 times)
MCDoubleDefDP
It would be great if we could customize the fields that appear on the Tags tab of the Tag Editor. This could save a lot of clicks for those of us who have edit metadata in the [...] splitters or on the Tags (2) tab.
For example, I would add Guest Artist, Performer, and Remixer directly below Artist since I often have to edit those fields, and I would remove Conductor since I've never used it. I'd also add Language and my custom tag for Explicit.
Sofocl
belomeclone
+1
I often change the file name when I edit my music, or at least want to view the file name, and that is on a separate tab as well.
I wont do this request. You can customise the editable tags in the vertical tag editor panel and i dont plan to enhance the functionality beyond that
