Hi. When sending music files (albums) to an attached Sony Walkman, cannot get the artwork to transfer. Any clues?
Do you mean that:
1) the artwork doesn't transfer even though you have set it to do that in settings ?
2) the artwork is not showing when playing the file on your Walkman even though you have confirmed that it's been transferred?
If it's 2) then your Walkman might not support the currently selected artwork storage option and you should try changing it to something else
