Author Topic: Virtual Tag that shows either <.Ext> or <Format>  (Read 490 times)
Gendji
Is it possible to make a virtual tag that shows either the <.Ext> tag if it's a local file playing, or the <Format> tag when a Radio Station is playing?.
So basically when a local file is played only show <.Ext> but not <Format> and if a Radio Station is playing, only show <Format> but not <.Ext>.
ma_t14
One way to achieve this is by checking if <Path> has a value. Naturally it won't for radio streams
$IsNull(<Path>,<Format>,<.Ext>)
I'm sure there are other ways to differentiate radio streams from local files
Last Edit: March 03, 2022, 02:21:00 PM by ma_t14
