Hi
I think I asked this before but I need to ask again. WHAT file does this info reside in for the Relink Music File Paths? I've found a couple of .ini files but there is nothing in them about this. Every time I want to redirect my older playlist to the new location I get this, below, filled in so I have to delete all of those filled in, useless paths so I can proceed. It keeps me from really getting things done with rerouting these playlists as it's so annoying.
Every time I dismiss the panel and then bring it back up to put in some new edited paths those older paths are put back in EVERY SINGLE TIME
ANNOYING!
So it would be nice to know if there is a way to tell MusicBee to FORGET those paths and if not then an editable file to delete them once and for all
Thanks so much!
Richard
It's a link to download and look at the image. I'm not having ANY luck with IMGUR using the Insert Image tool here! AND the code here is really weird, I went to edit the post and it was all messed up and wouldn't let me save it so I had to Cancel, Copy the text and Delete the post and start over! Grrrrrrrrr Here is the direct link to the image file from my IMGUR
https://imgur.com/a/tCCtoKS
