Author Topic: Can playlist be restored that I accidentally deleted?  (Read 1083 times)
LtTawnyMadison
Hi, I searched this forum and the guide but couldn't find an answer. I meant to delete just one song on a playlist but didn't realize I had the whole playlist selected. I don't recall if there was a warning, but of course the playlist is gone and I'm wondering if there is any kind of 'recycle bin' like Windows has, or a way to "un-delete" it. I did try the undo keyboard shortcut but that's about it. I can import it from my phone but I had just made a lot of changes to it in MB.
The playlists are all files in the Playlist folder under the same folder as your library (*.mbl) file, so your system backup will have a copy.  Even auto-playlists are there.
Anything deleted by MusicBee should be in your actual recycle bin.
