Hi All,
I have M/Bee version 3.4.8033
Windows 11
I have a bit of an irritating problem here, that I am hoping someone can help me out with it.
In the centre panel where I display all my record from A to Z.
If I wish to add a song to my playlist I right click on the record
Drop down menu appears
Add to playlist
I see 2 duplicate playlist
It looks like this on my screen.
Press Ctrl to multi-select
Steve’s-Playlist
Steve’s-Playlist
<New playlist>
External playlist
I only created one playlist.
I have tried removing both playlist from within M/Bee and starting again,
which does not work.
I have located the program installation folder
C:\MusicBee\Library\Playlists\
and deleted "Steve's-Playlist.mbp"
and re started M/Bee version 3.4.8033
The playlist is still there?
How can I remove it?
Is there an *.ini file I can edit to fix the problem?
Any suggestions in how to fix this problem are welcome.
As A side Issue:
I have another PC sat at the side of this one I am using,
and this is running the same version of M/Bee version 3.4.8033.
There is no problem with the playlist on this one?
Thank You......
