Author Topic: Option to delete tracks via mobile device / streaming?  (Read 1105 times)
Nixander
Hi everyone,
I am looking for a possibility to delete tracks in my mb library when I listen to my library via my smartphone.
I want to listen to tracks in my inbox (while I am commuting: with my smartphone) and decide, which one I want to keep and which one I want to delete.
I have a media server at home. Maybe a possibility with two way sync is possible to... For example moving tracks which should be delete to a specific playlist?
Maybe anyone has good ideas :)
Thank you very much!
Try the MB WiFi Sync app from the Play Store. It allows reverse syncing when using GoneMad or PowerAmp music players. I know it will reverse sync playcounts and ratings. I don't think it has the ability to sync files that are deleted from the device.
https://getmusicbee.com/forum/index.php?topic=28093.0
Further questions/discussions about WiFi syncing should be posted in the referenced thread.
