Author Topic: Stick Figures Visualization  (Read 20504 times)
silasje1
website where this is from:
http://www.wischik.com/lu/senses/sticky/
EDIT 2012:
The plugin is not supported by me anymore. Please download the plugin install and then it would appear in the list ;)
Last Edit: April 18, 2012, 03:19:16 PM by Silas Arentsen (Silasje1)
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
VX
Hi, silasje1  :)
Thanks for the new plugin for MB. However, I must admit that it doesn't work as expected for me :( I've created the 'Plugins' folder inside the MusicBee folder and extracted the *.rar file there. I can't see the new visualization to choose in the MusicBee menu though.
silasje1
Hi, silasje1  :)
you must use lowercase. The main dll file(s) must be in there if i packed it wrong. It can be found in visualizations menu.
Dutch Translation
WMP 12 Skin
VX
Hi, silasje1  :)
I've used lowercase and extracted the stickfingplugin to the folder. But it doesn't help.  :(
Maybe someone else could confirm that the plugin works as expected ???
cartman005
Yes, it does not seem to be working for me either.
you need to rename it to vis_sticky2.dll
(all winamp visualisation plugins need to start with "vis_" for MB to recognise it
however once you do that there are 2 choices, "sticky" works but "sticky2" doesnt work and hangs MB
silasje1
hope it works now. Changed it to vis_sticky. But on my pc the dll without vis__ works?
Dutch Translation
WMP 12 Skin
