Author Topic: Soundtrack titles/pictures will illegal characters in name  (Read 731 times)
sataraid1
After playing around and doing some reading, I finally figured out how to have specific pictures for soundtracks to appear in the "Now Playing" tab. One minor hangup, though.
I have a lot of soundtrack titles that have a colon ":" in the title. Yet I can't have a picture in the Soundtrack Pictures folder with a matching filename, because you can't use a colon in a filename.
Is there a workaround? Is there a different tag I can put the windows-approved filename and have it use that to match the picture?
Or do I just need to clean up all my soundtrack titles with forbidden characters and be done with it?
Thanks in advance!
  • Heal The World
Try this for now...in place of the illegal character, insert an empty space.
So if you have an album named Tron: Legacy, use Tron  Legacy for your filenames and see if MB picks up the images.
having a quick look at the code it looks like the invalid character mapping used for the file organiser is used
By default ':' will map to a space so Mayibongwe's suggestion should work
sataraid1
That suggestion did indeed work, thank you very much!
And how did you know I was listening to Tron: Legacy when the issue popped up? ;D
  • Heal The World
Glad I could help.
Crazy coincidence ::)
Do you also collect your own movie backdrops for every soundtrack that you have?
If so, do you mind sharing the sites that you use? (I normally use IMDb and FilmGrab. I could use a few others too)
sataraid1
I listen to a lot of soundtracks, so I will probably add backdrops as I listen to albums for the first time in MusicBee.
I do already have a large folder of pictures from movies and shows that I use for desktop pictures, but most of them were just collected over the years from various sources.
I've hit this website for screen caps quite a lot in the last few days, it seems to have some pretty good stuff:
https://movie-screencaps.com/
