Author Topic: Incorrect DSD frequency on the DAC's display (USB, Amanero)  (Read 460 times)
beeUser
Hello!
I need help.
When I use files in DSD-format (DSD128, DSD256) DAC's display shows 88.2KHz instead of 5.6MHz or 11.2Mhz.
I haven't got the same problems with Foobar2000 or Bug head.
I've tried through ASIO (Stream RAW DSD data) & WASAPI.
DAC connected to my PC (Windows 11) by USB (Amanero).
hughbeyond
I am facing the same problem. when i use the hugo2 to conecting pc ,with musicbee software, using dsd format file ,i found that my hugo2 display the low quality with red light, i can't found how to set in Musicbee , how can i do ? Thanks
