ffmpeg.exe - which should also come with MusicBee
@rgujiohgrwuio: Just to clarify, what Zak means is ffmpeg.exe would be a good additon to MusicBee, not that it does come with MusicBee--it doesn't.
Nope, I thought it was already included with the full MusicBee install. I have it, but must have added it myself.
I don't think it should be included with MusicBee. The smallest ffmpeg build would add around 50MB to a MusicBee installation,and it isn't needed for common music management tasks.
A compiled Windows executable can be downloaded from here:
www.gyan.dev/ffmpeg/buildsUnzip the
ffmpeg.exe file into the
Codec subfolder where you have MusicBee is installed.
