Author Topic: Album Auto - Tag Repeats Tracks 10 and Higher as Track 9  (Read 508 times)
Jaslan
If I use Album Auto Tag on an album with 10 tracks or more, the 9th track is repeated in place of tracks 10 and above.  But if I deselect one of the tracks for tagging, it corrects the repeated tracks.  Except, it often leaves off the last track.  But if I click Apply, it does actually tag the last (unshown) track.  I have tested it with many albums and it seems to always happen with 10 or more tracks.  I am using version 3.4.8033.
Anyone else getting this behavior?
JL
I think I know what you mean, but can you post a screen shot for clarity? Thanks
Jaslan
Before clicking to deselect a track for tagging....
Then, after deselecting a track, it looks like...
This...
But, I noticed, that I had the Album Tagger window at its smallest vertical size when it was doing this behavior.  If I enlarged it a little bit, it was fine.
So, it seems to only happen if the tagger window is at its smallest vertical size.  Making it bigger (even if the tracks still don't all fit and a scroll bar is present), seems to cure the display error.  I am on a 4K display with 150% scaling though, so that might be part of the problem.
EDIT:  Ok, so I switched my display to 100% scaling and the problem is gone, even with the window at the smallest size.  So, easy workaround, even with 4K and scaling is to make sure the window is enlarged a little bit.  Something about the minimum size causes the tracks to display improperly.
Last Edit: January 26, 2022, 02:21:30 PM by Jaslan
