Author Topic: Right sidebar. Can I have both "Lyrics" and "Track information" panels?  (Read 1017 times)
Skakner
Hello everybody!
Is it possible to have on the right sidebar (under the "Playing tracks" panel), both the "Track information (Album Cover)" and the "Lyrics" panels?
With the current settings, I can see only one of them ("Lyrics" or "Track information)".
Can I see them both?
Thanks!
Sure, just untick the "stack" box for each of them on the layout window. Although you may find the panel gets pretty crowded with all that.
Skakner
Thanks for the quick answer!
Well, it's a little crowded indeed.
I think I'll keep the previous arrangement (changing between Lyrics and Info). "Lyrics" panel isn't so frequently necessary after all.
Thank you!!
