its very hard to follow
So you started MB, dreamhop music was the initial playlist and it was sorted correctly? Was its sort order date added (album) (desc)?
Then you clicked on Chillhop which was incorrectly sorted alphabetically. If you click the sort menu at that point what does it show?
And then you clicked another playlist and back again to Chillhop which is now sorted correctly by Date Added
When I started MusicBee, Dreamhop music was the initial playlist and it was not sorted correctly. None of my playlists were. They were incorrectly sorted alphabetically (the way my main library is sorted).
Its sort order was set to date added (album) (desc), as were the other playlists I showed.
Clicking the sort menu shows the correctly chosen date added (album) (desc) sorting, despite it actually sorting alphabetically.
The third playlist I clicked was also sorted incorrectly, then I hit f5, which made it sort correctly. Then, all my playlists were sorted correctly.
Whether or not the playlists were sorted correctly, the sort menu always said they were being sorted by date added (album) (desc).
It does this about 1/3 times I start musicbee.
