Author Topic: How to "Search and Replace" special characters?  (Read 1855 times)
asdasdasd223
I'm trying to remove "; Example" from "Test; Example" in the Genre tag. But when I use "Search and Replace" it says "No Matches Found". When I search for only "Example" then it finds everything. Why does ; screw it up?
I have Advanced Search and Replace but every preset is way too specific like "Remove EVERYTHING after and including <Custom Text 1>" which would mess up tags that have stuff after what I want to remove:
"Test; Example; I want to keep this part"
What else can I do?
  • Heal The World
$Trim($Replace($Replace(<Genres>,; Example,),Example;,))
That's all that was needed I guess.
Last Edit: January 17, 2022, 07:00:30 PM by Mayibongwe
Favourite song at the moment:   Decode by Paramore
The Incredible Boom Boom
The semicolon is the visual representation of the NULL character value in multi-value tags.
You don't have to include it in your searches, just remove "Example."
If the question is strictly about removing certain characters in tags, that would work.
But I am guessing the OP wants to remove a complete value in a multi-value tag.
As it happens I struggled with something like that myself recently, and I failed to find a good solution.
Suppose a track has values for the tag 'Keywords' such as: aaa, bbb and ccc, and you want to remove the bbb value.
By simply using text replace, you would get something like this:
So this would probably need some regex magic.
I've tried a few solutions, using anchors for start/end etc., but none of them worked perfectly for all these examples.
So I am interested too if someone has the perfect solution.
Hm, this seems to work:
I would swear I tried something like this before and failed.
So anyone interested, try it out on several situations before you decide to use it on your valuable library.
  • Heal The World
@hiccup, don't virtual tags work for the scenarios you described above? (using the replace function to replace a value in <keywords>)
Oh, ok, that makes. In that case...
search for:
Example.+?(\w)
replace with:
$1
And check the regular expression box
<Genre> only returns the first value. <Genres> returns all of them.
  • Heal The World
Never had to use <Genres> before, so I didn't know about it. Thanks for letting me know that.
Yes, but that will only work for displaying purposes, using that virtual tag.
Using an AT&RT preset like this will remove the tag from the file/library, so it won't display anywhere any more.
  • Heal The World
Oh okay I see. Thanks. I've always preferred using virtual tags (I find it easier than using the regEx you mentioned) and then using the AT&RT to copy the virtual tag into whatever tag I was dealing with.
To each his own, but if you use such a feature frequently it's much easier to have an ASR preset available for it.
You can then e.g. simply have a shortcut to open it.
I already have one for adding a specific tag to existing ones:
https://getmusicbee.com/forum/index.php?topic=35032.0
I'll add a download for this 'remove a tag' ASR preset to the above post at a later moment.
(after I am confident it indeed works well and is reliable)
After some more testing and some refinements I am now confident it works well.
The presets can be found and downloaded here:
https://getmusicbee.com/forum/index.php?topic=35032.msg191625#msg191625
