Author Topic: Help with file organisation syntax  (Read 509 times)
wombleywoo
Hello,
I am taking advantage of Musicbee's automatic file organisation feature. I am trying to get Musicbee to rename and organise my files in a way that PleX likes to read them.
This has been pretty easy, but I am struggling with disc numbers. Here are PleX's instructions:
"For albums that span more than one disc, you simply prepend the disc number to the front of the track number. So, track two on disc three would be "302 - TrackName.ext"
This works great, except when disc numbers are not present in my iD3 tags (usually because there is only one disc). This results in a file name which is: "Unknown Disc#05 - Going.mp3"
Can I set up the syntax in such a way where IF the disk doesn't have Disc values in its iD3 tag, it will ignore that string, resulting in: "05 - Going.mp3"
Thanks!
Yes, you could use this construction to skip the disc #:
$IsNull(<Disc#>,,<Disc#>)
Or if you want to use Disc 1 when the disc # is blank:
#IsNull(<Disc#>,"1",<Disc#>)
