Author Topic: Exporting MB mp3 files to an SD card for the car with Tags  (Read 589 times)
SteveBlue
I'm looking for some help with getting my musicbee mp3 files onto an sd card for use in the car but I can't seem to workout why the album artwork tags don't transfer as well when i copy to the card?
Jaslan
On the tab for the SD card, in the settings, at the bottom, there are options for the art. Have you checked those?
SteveBlue
Any idea what it should be set to?  It already had embed artwork in the music file but that doesn't work?
It would need to be set to whatever your car's device requires. Find that out and then set MB to the same format.
