Author Topic: Equaliser and Auto-Select by Genre  (Read 1033 times)
  • MB Version: 3.6.8878 P
Is it possible to have the equaliser use the 15-band option with Auto-Select by Genre?
I assume you are basing that on the fact that the equaliser settings panel shows as 10 bands
In fact when it comes to the actual equaliser used, as long as the genre.sde file has 15 bands then that is what will be used.
If the next genre.sde file only has 10 bands then 10 bands will be used
Yep. That was my assumption (obviously incorrect now  :o  )
I'll just go ahead and rename all my <Genre>_15.sde files now.
BTW If a file has multiple genre tags, is only the first tag used?
