Author Topic: Column not displaying properly  (Read 523 times)
musicmafia
Newb here, loving MB so far. This is no biggie, just something that OCD types like me would notice. The TIME column in the Main Panel seems to be the only column that is right-justified. All other column headers and data in those columns display along the left side of the columns. Is there a setting where I can fix this or can it be adjusted? Not sure if others are seeing the column displayed the same way? Thanks!
I think that's pretty standard.  Time is one of the few variables that would expand to the left; seconds are never going to be more than two digits so to remain aligned they'd be right justified.  The gain fields and a couple other numerical fields are also this way.
This is adjustable under Edit->Edit Preferences->Tags(2)...fields: Configure Fields
musicmafia
THANKS! I adjusted it to accommodate my OCD and all is good now  ;)  Appreciate the tip. Now I know where to customize those :)
