Author Topic: Equalizer presets not showing in dropdown list  (Read 744 times)
BillH
I'm having a problem.  None of the presets are showing in the dropdown list for the equalizer.  The .sde files are in C:\Program Files (x86)\MusicBee\Equaliser.  This is where they were installed since I haven't touched anything.  The only two items in the dropdown list are Manual and Auto-Select by Genre.
Shouldn't all the presets be listed?
I am using the installer version of MusicBee 3.4.8033 which I downloaded from the MusicBee website.
Any ideas what I am doing wrong?  I couldn't find any kind of setting that would impact this.
I originally posted this in another topic which was labeled as "Solved", so I thought I should break it out into its own topic.  Sorry if that was incorrect.
Thanks,
Bill
its actually looking in
%AppData%\MusicBee\Equaliser
for future updates i will ensure that folder is populated but for now just copy the Equaliser folder from the musicbee installation folder
this fixes the issue:
i have changed my mind and this will be part of the installer script. You can still perform the manual steps above
Last Edit: January 15, 2022, 11:54:49 PM by Steven
