Author Topic: Any way to make this 1px line invisible by edditing the skin file?  (Read 749 times)
beestard
Basically title. I would like to hide the faint 1px line in-between the right and right-main panel which I have highlighted in red. Is there a way to do this by editing the xml? I want to do this because its visible against my background image. Please & thanks.
Look for this element in your skin file and delete the bdr attribute from it and see if that does it.
element id="Panel.Body.Default"
A good thought/suggestion, but it looks like it doesn't work?
I just tried solving this by adding transparency to the element, but that also didn't work.
So this probably would need to be a wishlist request.
Have a look here...I tested this with the sample skin. Image 1 has no bdr attribute.
Unless I'm mistaken about the border that beestard wants gone. It's the right sidebar bdr right?
Note that the OP is using a custom background image.
Have you tested this using that?
Yeah you're right. That method won't work when a custom background image has been set. Sorry about that.
