Author Topic: Update paths option please  (Read 1135 times)
RAMWolff
So I have a new computer and I had to change where allot of what I had on the old rig so the paths in the saved backup for MusicBee is annoying me to no ends here.  It would be nice if you could drag and drop  the songs to the playlist and have an option to update paths to the existing songs already in the playlist.
I've tried setting the path in the preferences but it's not fixing this issue for me.
Thank you
Richard
Have you tried the "relink music file paths" command? It's in the File menu, I think under Library.
RAMWolff
No and when I tried that all my playlists disappeared so that's no good either!   :(
RAMWolff
To add when I try to update the path to each song in the Edit> Properties tab nothing happens.  So that's no good either.  There must be a way to do this , since this is a wish list forum, have this implemented.
