Hi.
Regardless of what tags or settings you use, in any given view MusicBee will display a track once, and once only.
So sadly, the answer to
Is there a way to assign multiple information to the same mp3 or flac files, so that they are displayed separately is
no.
The only currently available workaround is to keep one main copy of each album, and create the other album versions using ASX files that point to the original files, but have their own tag values.
MusicBee's support for ASX files can be sketchy, and creating and maintaining them is painful, so before you decide to do that I'd strongly recommend asking yourself whether it's worth the time for what seems a pretty niche use case. (If the tracks are all exactly the same, why do you want to show different album versions? Some albums have dozens of different releases.
It looks like old forum threads on the use of ASX files have been purged - the search results don't show some very early discussions - but this thread shows the idea:
https://getmusicbee.com/forum/index.php?topic=24465.msg141184There have been various requests over the years for the ability to create "virtual albums" to address cases like this (but specifically for compilation albums), but none have had gained much momentum.
