Author Topic: Clickable URLs  (Read 3777 times)
Nighthawk_NL
Hi phred,
I have followed your guide and everything is set up but the link is not clickable in the way that I can directly open the youtube link for instance. I can cut and paste the link of course but that is not what I meant. Please see below what I mean:
I have entered the link of Queen - Bohemian Rhapsody in MusicBee.
https://www.hitnoteringen.nl/hitlijsten/radio-10-top-4000/2021
If would be very nice if the new link field could just show a youtube play icon for instance so you can directly see that the MP3 file has also has a videolink attached and when you click on it it automatically opens youtube.
Looking forward on your thoughts about this.
Thanks Nighthawk_NL
That's not the way it works. You need to have the link displayed in a custom tag so that it becomes clickable. It doesn't show any icons.
Download the latest MusicBee v3.5 beta patch from here.
Check out the MusicBee Wiki.
How to post screenshots is here
did you set the data type for the field to Url in Tags(2)/ Fields Configuration ?
Thanks for catching that, Steven. I've updated my instructions.
If I were to send one of my tracks which has a clickable link tag (embedded) to someone who uses MB, but hasn't set up the custom tab, what would they see?
Obviously if I sent it to someone who doesn't use MB they wouldn't see the link at all, correct?
they can see it in the tag inspector, any mp3 tagging tool or as a tag if they have a custom tag defined with the same name you are using
Thanks Steven.
Nighthawk_NL
Hi phred, thanks again for all your help and insights but whatever I do I still can't find a clickable link in MusicBee. Obviously I have missed something but I really don't know what to do to see the clickable link.
Post screenshots of the following making sure to include the new tag in the screenshot:
- Your custom tags configuration from Preferences > Tags1
- Your configure fields configuration from Preferences > Tags2 > fields
- The Tags (2) screen from the tag editor
- The configuration of your track information/details panel
What is the name of your custom tag?
