Author Topic: Clickable URLs  (Read 7458 times)
$RxMatch(<Comment>,"(^|\s)https?\:\S*|(^|\s)www\.\S*")
Seems to work nicely. There may be a few "http:\\" floating around. I changed your code to
http?\:\S*|
And it didn't show anything. I tried with
http*?\:\S*|
and
http*?\:\S*|
and again nothing.
And it did find one that had no protocol, but simply "www.website.com" so that was a nice touch.
My thinking is that the ? after http in your original is a single character wildcard and therefore should show both "http" and "https". Is that correct? If so, and it's not turning up any "http:\\" then perhaps I have none.
Thanks for putting this together.
The 's?' part in https? means that the letter s may or may not be present, and so both http and https will be matched.
(same as e.g. "bees?" would match both one bee and a swarm of the little f*ers)
I first looked on da webz for examples of url-finding regexes. But pretty much all of them were quite complicated, and I couldn't even get them to work.
So I built something simpler. Probably too simple ;-)
Can you post a couple of comments containing url's that fail using this formula?
Perhaps I (or somebody else more talented with regex) can create a better regex.
edit:
Having read your comment again, and now probably digesting it a bit better, I suspect that the regex/formula is actually working perfectly fine?
Last Edit: January 12, 2022, 05:18:51 PM by hiccup
Ah HAH!!
I have finally found a mistake you made. "bees?" would -not- match "bee" but would match "bees" and "bees" plus one other character. To match both "bee' and "bees" it should be "bee?".
I may not know RegEx, but I know my wildcards.
Yes, it's working fine. Your confusion may have come from my statement that I -think- there are some "http:\\" strings out there, but so far I haven't been able to find them. So if your RegEx isn't finding them, and I'm not finding them, then they don't exist. And to proof it to myself (and to you) I changed one instance of "https:" to "http" and it showed up.
A tip of the ol' phred hat to Mr. Hiccup.
Last Edit: January 12, 2022, 06:01:54 PM by phred
It surely would ;-)
It is kind-of-a wildcard, but a special one that only looks one step back.
(don't you have leftfield members in your family that do weird things?)
Last Edit: January 12, 2022, 05:52:49 PM by hiccup
It surely would ;-)
I'm not convinced. My understanding in the use of the question mark as a wildcard is that where the question mark is, it will allow any one character. So in said example, "bees?" would return the first four characters (bees) plus any other -one- character in the fifth position. Whereas " bees* would return "bees", "beeshit", or "beeswax".
Again, I think not. Unless RegEx is different from BASIC. But lookee here:
Quote from: https://support.cleo.com/hc/en-us/articles/360027263194-Using-Wildcards-and-Regular-Expressions
Wildcards
Wildcards are represented by * or ?, where * matches multiple characters and ? matches only a single character.  For example, assume the outbox has the following files.
ab1.edi
ab2.edi
ab11.edi
ab12.edi
The following commands produce the following results.
Command Result
PUT ab*.edi Sends all four files from the outbox
PUT ab?.edi Sends only ab1.edi and ab2.edi
I'm the only member of my family that does weird things. I'm not left-handed and I'm not out of left field.
https://docs.microsoft.com/en-us/dotnet/standard/base-types/regular-expression-language-quick-reference
"? Matches the previous element zero or one time."
Also, doesn't my formula by itself prove that this is how it works?
But this has drifted off-topic:
Does my suggested virtual tag extract any url present, in all the comment fields that you have tested it on?
If not, please share an example of a specific comment where it fails, so that I (or someone else) can try to improve it.
Yes, it works. I stated as such in Reply #17.
Upon further review, my understanding of ? and * as wildcards comes from DOS and BASIC. RegEx is different. Yes, I'm old.
This has the change:
That reply mentioned 'it seems to work'.
Followed by other things you tried editing the regex.
It's probably me (sometimes being a bit too Aspergic about words) but I didn't read that as a definite confirmation that the regex/formula is functioning to complete satisfaction.
But I now guess the conclusion is that it does? Which frees up the assigned brain cells to other tasks. (such as dreaming sweat dreams)
Last Edit: January 12, 2022, 10:21:21 PM by hiccup
Thanks Steven. It works great and is a real time-saver.
Onward and upward to 3.5!
Using 3.5.8048 P
I set up a custom tab and named it "Link" and set it to new URL type.
When I do a custom search and set the first field to "Link" the second criteria field has nothing in its dropdown. At the very least I was expecting "has a value" or "has no value" but it would be nice if all the options available for the other first field tags were available here. This feels more like an oversight than a bug, which is why I've added it to this thread.
Last Edit: January 14, 2022, 11:50:27 AM by phred
Nighthawk_NL
Great, when this is possible can anyone explain to me how I can add a clickable link so I can also choose a YouTube video instead of the local MP3 file.
It's available in the latest 3.5 patch. See my signature for link and instructions.
- Preferences > Tags (1) > custom tags > name the tag (I used "Link") and save it as a tag you're not, and will not, be using for anything else. This keeps the tag embedded in the music file and not in MB's database.
- Preferences > Tags (2) > tag handling > fields: configure fields > find your newly created custom tag > set the type to "URL." Note that you will not find the newly created tag in alphabetical order. It will be under CustomX, where X is the number of the custom tag.
- Select the file(s) where you want to have the link appear > Tag Editor > Tags (2) > find the custom tag you created in step 1 > enter the link
- Make sure you have the Track Information panel showing in your layout > click on the header where it says "Details" > Customize Panel > in the fields section add the custom tag you created in step 1 > save
You're all set.
Last Edit: February 06, 2022, 03:59:07 PM by phred
