Bonsoir,
Karbock, I tried to do the process you indicated...and it gives this as a result ??
Bonsoir, Anatole.
Oops, there was a mistake in step (4.9) due to distraction. I have corrected it in my previous post.
You can correct it in mp3tag like this:
* Select Menu Actions -> Actions (or [Alt+6]).
* Select "
AA to AAsort - 1 given name".
* Click on the second buton (Modify).
* Select the 2nd row and click on button Modify again.
* In the third zone, replace "
$upper($1), $2" by "
$upper($2), $1" and confirm.
* Apply the updated action (
AA to AAsort - 1 given name) to the concerned tracks.
Next step, I guess, is to use this in "Musicbee/ Settings/Display order" but how ??
There are two possible ways.
FIRST OPTION (the simpler one):* Open dialog Preferences -> Sorting/Grouping.
* Make sure that the box to the left of "enable custom sort values..." IS NOT ticked (FR: définir les critères de tri personnalisés).
* Browse your collection by "Album Artist Sort" instead of "Album Artist":
- Click on the main left panel header showing "Album Artist"
- Select Other tags -> Album Artist Sort.
SECOND OPTION:(1) Activate the sorting criteria in MusicBee:
* Make sure that the box to the left of "enable custom sort values..." IS ticked (FR: définir les critères de tri personnalisés).
(2) In the same dialog box, remove the incorrect sorting criteria:
* Click on button "Artists..."
* Click on button "Show as text".
* Empty the list (click in the edit box, [Ctrl+A], [Delete]).
* Confirm (button "Save" twice).
N.B.: Step (2) above is necessary if you updated your MusicBee library after defining incorrect AlbumArtistSort values with mp3tag.
You can also delete the values on a case-by-case basis with the [--] buttons.
(3) Update your library, by pressing [Insert].
(Or: Menu MusicBee -> Files -> Scan folders for new files.)
And I have a new question!! I found out that part of the "album artist" tags are empty...: How, with Mp3tag, automatically copy the contents of the "performer" tag into the "album artist" tag
* In the main panel, select the concerned tracks.
* Menu Convert -> Tag-Tag (or [Alt+5])
* Field:
ALBUMARTIST* Format string:
%artist%* Confirm.
