Author Topic: MB hangs when clicking any split button  (Read 3849 times)
https://www.mediafire.com/file/i65kfxuemcyes71/MusicBeeDebugSplitter.zip/file
replace musicbee.exe
on restarting after it has hung, check the error log (help/ support/ view error log) and send me the info dated today
Rostech
Thanks Steven. Closed MB, replaced the file, relaunched it, clicked a splitter. Hung. Here are the log messages:
2022-01-19 5:12:15 PM - shared start
2022-01-19 5:12:15 PM - enumerate all values
2022-01-19 5:12:15 PM - enumerate done
2022-01-19 5:12:15 PM - new start location={X=1206,Y=409},screens=2,bounds={X=0,Y=0,Width=1920,Height=1080},field:Composer,ac=231
2022-01-19 5:12:15 PM - 1
2022-01-19 5:12:15 PM - 2
2022-01-19 5:12:15 PM - 3
2022-01-19 5:12:15 PM - 4
2022-01-19 5:12:15 PM - 5
2022-01-19 5:12:15 PM - 6
2022-01-19 5:12:15 PM - location changing: {X=4540,Y=635}
2022-01-19 5:12:15 PM - location changed
2022-01-19 5:12:15 PM - pt={X=4540,Y=635},location={X=4540,Y=635,Width=738,Height=528}
2022-01-19 5:12:15 PM - create control
2022-01-19 5:12:15 PM - shown
2022-01-19 5:12:15 PM - ready
Rostech
I can finally reproduce the issue! Your log gave me a clue, given all the coordinates and location information. I'm running a laptop and an external monitor. When I run MB in the external monitor, it works without issue. When I run it on the laptop screen, it hangs. The screen resolutions are 1920 x 1080, 150% scale (laptop) and 1920 x 1080, 100% scale (monitor). When I changed the laptop scaling to 100%, it worked consistently. I do have to change it back because these eyes don't do 100% on a laptop anymore, but at least I know what's causing it. A fix would be great at some point, if possible, as I won't always be connected to the external monitor.
I am confused what is happening for it to go wrong in MB, so could you repeat with this debug version - same link and instructions
Rostech
So yesterday I was able to reproduce the issue seemingly predictably and at will. Today, with your latest debug version, nothing I do causes it to happen. (I like it much better when things fail consistently!) I will continue to use this version of MB and I'll post the log if and when it happens again.
Steve
it will still be helpful if you sent one set of log entries
Rostech
Okay, here are the most recent entries today (still working well):
2022-01-20 11:10:54 AM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=194,Y=137}
2022-01-20 11:10:54 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:10:54 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:10:55 AM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 11:10:57 AM - bounds={X=272,Y=458,Width=738,Height=528},dpi=1.5
2022-01-20 11:10:57 AM - set bounds form={X=0,Y=0,Width=738,Height=528},pt={X=272,Y=458}
2022-01-20 11:10:57 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:10:57 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:10:57 AM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 11:11:14 AM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=194,Y=137}
2022-01-20 11:11:14 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:11:14 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:11:14 AM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 11:11:24 AM - bounds={X=272,Y=458,Width=738,Height=467},dpi=1.5
2022-01-20 11:11:24 AM - set bounds form={X=0,Y=0,Width=738,Height=467},pt={X=272,Y=458}
2022-01-20 11:11:24 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:11:24 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:11:24 AM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 11:25:08 AM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=194,Y=137}
2022-01-20 11:25:08 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:25:08 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:25:08 AM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 11:25:12 AM - bounds={X=272,Y=458,Width=738,Height=467},dpi=1.5
2022-01-20 11:25:12 AM - set bounds form={X=0,Y=0,Width=738,Height=467},pt={X=272,Y=458}
2022-01-20 11:25:12 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:25:12 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:25:12 AM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 11:25:22 AM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=3586,Y=260}
2022-01-20 11:25:22 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:25:22 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:25:22 AM - screenarea={X=2880,Y=0,Width=2880,Height=1548}
2022-01-20 11:25:29 AM - bounds={X=3785,Y=484,Width=738,Height=528},dpi=1.5
2022-01-20 11:25:29 AM - set bounds form={X=0,Y=0,Width=738,Height=528},pt={X=3785,Y=484}
2022-01-20 11:25:29 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:25:29 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:25:29 AM - screenarea={X=2880,Y=0,Width=2880,Height=1548}
2022-01-20 11:26:12 AM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=486,Y=83}
2022-01-20 11:26:12 AM - screen wa={X=0,Y=0,Width=1646,Height=854},bounds={X=0,Y=0,Width=1646,Height=926}
2022-01-20 11:26:12 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:26:12 AM - screenarea={X=0,Y=0,Width=1646,Height=854}
2022-01-20 11:26:12 AM - location reset5={X=486,Y=65}
2022-01-20 11:26:15 AM - bounds={X=508,Y=303,Width=738,Height=528},dpi=1.5
2022-01-20 11:26:15 AM - set bounds form={X=0,Y=0,Width=738,Height=528},pt={X=508,Y=303}
2022-01-20 11:26:15 AM - screen wa={X=0,Y=0,Width=1646,Height=854},bounds={X=0,Y=0,Width=1646,Height=926}
2022-01-20 11:26:15 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:26:15 AM - screenarea={X=0,Y=0,Width=1646,Height=854}
2022-01-20 11:29:17 AM - set bounds form={X=0,Y=0,Width=994,Height=502},pt={X=515,Y=120}
2022-01-20 11:29:17 AM - screen wa={X=0,Y=0,Width=1646,Height=854},bounds={X=0,Y=0,Width=1646,Height=926}
2022-01-20 11:29:17 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:29:17 AM - screenarea={X=0,Y=0,Width=1646,Height=854}
2022-01-20 11:30:06 AM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=486,Y=65}
2022-01-20 11:30:06 AM - screen wa={X=0,Y=0,Width=1646,Height=854},bounds={X=0,Y=0,Width=1646,Height=926}
2022-01-20 11:30:06 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:30:06 AM - screenarea={X=0,Y=0,Width=1646,Height=854}
2022-01-20 11:30:14 AM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=486,Y=65}
2022-01-20 11:30:14 AM - screen wa={X=0,Y=0,Width=1646,Height=854},bounds={X=0,Y=0,Width=1646,Height=926}
2022-01-20 11:30:14 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:30:14 AM - screenarea={X=0,Y=0,Width=1646,Height=854}
2022-01-20 11:31:34 AM - set bounds form={X=0,Y=0,Width=994,Height=502},pt={X=515,Y=120}
2022-01-20 11:31:34 AM - screen wa={X=0,Y=0,Width=1646,Height=854},bounds={X=0,Y=0,Width=1646,Height=926}
2022-01-20 11:31:34 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:31:34 AM - screenarea={X=0,Y=0,Width=1646,Height=854}
2022-01-20 11:32:29 AM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=486,Y=65}
2022-01-20 11:32:29 AM - screen wa={X=0,Y=0,Width=1646,Height=854},bounds={X=0,Y=0,Width=1646,Height=926}
2022-01-20 11:32:29 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:32:29 AM - screenarea={X=0,Y=0,Width=1646,Height=854}
2022-01-20 11:43:12 AM - set bounds form={X=0,Y=0,Width=994,Height=502},pt={X=515,Y=120}
2022-01-20 11:43:12 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:43:12 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:43:12 AM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 11:43:27 AM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=486,Y=65}
2022-01-20 11:43:27 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:43:27 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:43:27 AM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 11:43:30 AM - bounds={X=467,Y=165,Width=738,Height=467},dpi=1.5
2022-01-20 11:43:30 AM - set bounds form={X=0,Y=0,Width=738,Height=467},pt={X=467,Y=165}
2022-01-20 11:43:30 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:43:30 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:43:30 AM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 11:43:34 AM - bounds={X=467,Y=165,Width=738,Height=528},dpi=1.5
2022-01-20 11:43:34 AM - set bounds form={X=0,Y=0,Width=738,Height=528},pt={X=467,Y=165}
2022-01-20 11:43:34 AM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 11:43:34 AM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 11:43:34 AM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 12:06:31 PM - set bounds form={X=13,Y=46,Width=894,Height=830},pt={X=13,Y=46}
2022-01-20 12:06:31 PM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 12:06:31 PM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 12:06:31 PM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 12:07:24 PM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=486,Y=65}
2022-01-20 12:07:24 PM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 12:07:24 PM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 12:07:24 PM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 12:07:43 PM - set bounds form={X=0,Y=0,Width=994,Height=502},pt={X=515,Y=120}
2022-01-20 12:07:43 PM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 12:07:43 PM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 12:07:43 PM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 12:07:51 PM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=486,Y=65}
2022-01-20 12:07:51 PM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 12:07:51 PM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 12:07:51 PM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 5:06:50 PM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=486,Y=65}
2022-01-20 5:06:50 PM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 5:06:50 PM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 5:06:50 PM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 5:06:53 PM - bounds={X=467,Y=165,Width=738,Height=528},dpi=1.5
2022-01-20 5:06:53 PM - set bounds form={X=0,Y=0,Width=738,Height=528},pt={X=467,Y=165}
2022-01-20 5:06:53 PM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 5:06:53 PM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 5:06:53 PM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 5:06:57 PM - bounds={X=467,Y=165,Width=738,Height=467},dpi=1.5
2022-01-20 5:06:57 PM - set bounds form={X=0,Y=0,Width=738,Height=467},pt={X=467,Y=165}
2022-01-20 5:06:57 PM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 5:06:57 PM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 5:06:57 PM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 5:08:25 PM - set bounds form={X=0,Y=0,Width=981,Height=789},pt={X=486,Y=65}
2022-01-20 5:08:25 PM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 5:08:25 PM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 5:08:25 PM - screenarea={X=0,Y=0,Width=1920,Height=1008}
2022-01-20 5:08:30 PM - bounds={X=467,Y=165,Width=738,Height=528},dpi=1.5
2022-01-20 5:08:30 PM - set bounds form={X=0,Y=0,Width=738,Height=528},pt={X=467,Y=165}
2022-01-20 5:08:30 PM - screen wa={X=0,Y=0,Width=1920,Height=1008},bounds={X=0,Y=0,Width=1920,Height=1080}
2022-01-20 5:08:30 PM - screen wa={X=2880,Y=0,Width=2880,Height=1548},bounds={X=2880,Y=0,Width=2880,Height=1620}
2022-01-20 5:08:30 PM - screenarea={X=0,Y=0,Width=1920,Height=1008}
