Used to just lock up occasionally. Then frequently. Now every time. Freezes at the end of whatever tune is playing when I click on anything. Have to use Task Manager to end. Tried disabling antivirus and all running programs. Using Windows 11, but also did this under Windows 10.
ERROR LOG:System.ObjectDisposedException: Safe handle has been closed
at System.Threading.WaitHandle.WaitOneNative(SafeHandle waitableSafeHandle, UInt32 millisecondsTimeout, Boolean hasThreadAffinity, Boolean exitContext)
at System.Threading.WaitHandle.InternalWaitOne(SafeHandle waitableSafeHandle, Int64 millisecondsTimeout, Boolean hasThreadAffinity, Boolean exitContext)
at System.Threading.WaitHandle.WaitOne(Int32 millisecondsTimeout, Boolean exitContext)
at System.Threading.WaitHandle.WaitOne()
at #=zE9$e2iN$kUtmGpiqCwI_y4M=.#=q3m9ifluAe9stDpF4chclVvBpx44NIkWHvT$oDEF5$kw=._Lambda$__0()
12/29/2021 4:33:09 PM - 10.0.22000.0 - 3.4.7805.33382 Store - System.NullReferenceException: Object reference not set to an instance of an object.
at #=zF1$yjYYxS0St$c2B3LpZNCKt97XS.#=zvh9Z89g=.#=zhV6ao4S9EtYz(String #=zeCfFY$Y=)
at #=zF1$yjYYxS0St$c2B3LpZNCKt97XS.#=z4otjcEpBwW_D.Dispose(Boolean #=zvOPUDw8=)
at System.ComponentModel.Component.Finalize()
SETTINGShttps://www.dropbox.com/sh/a546tjzlmbwpdtl/AAAHRbDcegO41puFgBQBOhkZa?dl=0NOTE: Re challenge question – a pumpkin is NOT a vegetable
