how do you personally handle the different years involved in classical music? Do you create custom tags for recorded, performed, composed etc? I know how (positively) obsessed you and all the other classical aficionadas in here can be, and I’m just trying to absorb all kinds of advice/tips…
I probably
have been obsessive about this, for the main reason that it was such a tough and frustrating matter to grasp and handle when I first sank my teeth in it.
My aim was probably to get a good and full understanding on the matter, and be able to retrieve, manage and benefit from having as much possible correct data (dates) as possible.
But, I think I have become a little bit wiser. (or just lazier)
These days I am not putting in excessive effort to have all sorts of dates populated and correct.
(except for that I have tweaked Picard as much as possible to do this automatically for me)For example, for my non-classical music library I don't care much about the recording dates.
Most popular music was originally released on LP's end CD's, and having their (first) release date is fine by me.
(I
might care about the specific release date for e.g. re-releases, when they have a very different track list, or are very different-sounding remasters.)
For classical music it's a different story. There it is the recording date that is most important.
Which is (should be) the date of the performance.
E.g. for famous performances and recordings that date from before the LP/CD era, I am mostly interested in having that recording/performing year correct, and the first date when it was released as an LP or a CD is of far less importance to me.
So, summarised:
For classical music I am mostly concerned with getting recording dates correct, and I put far less effort in managing and maintaining the other date types.
For non-classical music I am mostly concerned with getting the 'first released' dates correct, and I don't put too much effort in the other date types.
Obviously I do have created some specific custom tags and slightly complicated virtual tags to be able to manage dates so to get practical and sensible end-results for both classical and non-classical.
But after I made the decision a while back to have separate MB installs for my classical and non-classical music, this is one aspect that became a lot easier to manage.
I now don't need to use complicated virtual tags any more that have different outputs depending on if a track is of the classical persuasion or not.
My classical MB has dedicated virtual (and custom) tags, and so has my non-classical MB.
edit:
Another observation while giving this matter more thought. (again):
A lot of modern music doesn't even have a recording date that could be used or makes sense.
Constructing tracks in DAW software is not 'recording', and the dates that actual performers (musicians) performed and were recorded can vary a lot. And how about tracks that use audio samples from years or decades earlier? What would be the (singular) recording date for those?
