Author Topic: How to retrieve good quality genre tags using Picard  (Read 13436 times)
I was wondering if there is a way to use word wrap or if it's just something that'll come down to panel size and luck of the draw
When the tag splits the lines, it leaves the · behind.
Both are intentional.
- I don't like genre names getting cut-off to a next line.
If you want that you could simply use the <Genres> tag instead of my formula.
(disable 'split into rows' and set the number of rows that you want)
- The trailing middle dot indicates there are more genres to follow.
edit:
Playing around a bit with non-breaking spaces, I created one that seems to work nicely too.
It will neither truncate, nor cut-off a genre name to a next line.:
$Replace($Replace(<Genres>," ",$Char(00A0)),;$Char(00A0)," · ")
1. It requires the Additional Tagging & Reporting Tools plugin to be installed. (a recent version of it)
2. Set the panel to not split tags into rows. Set the max.row span to your preference.
Last Edit: January 30, 2023, 10:39:56 PM by hiccup
Mr. Trev
just to confirm I have this set up properly
This tag will remove all spaces from the genre - ie. deathdoommetal
Another thing that just popped into my head while working on this.
Does any part of your virtual tag limit the number of tags displayed (maybe the number of "0,4" instances or string of numbers at the end)?
My thought was if I wanted to have 5 genre available for library purposes, but only display the first 2 in the track info panel
So you also read/did this?:
Quote from: Mr. Trev
Nope.
Last Edit: January 30, 2023, 09:01:43 PM by hiccup
Mr. Trev
Yes, I did read that, and it was installed (v5.5.8397). I'll see if a newer version is available…
That's probably it.
The $Char function that the formula uses was added only recently to AT&RT, so an updated version is indeed necessary for this to work well.
