Author Topic: how to restore the library?  (Read 2887 times)
zuimeng
Backup the library, reinstall MusicBee, how to restore the library?
  • Heal The World
When opening the new MusicBee install, you'll be asked to select a library.
Click "create new" and at the bottom of the pop up, they'll be an option to select an existing library.
So click that and go to wherever your library is backed up and just select it.
You can find the same options by going to File -> Library -> Create New Library. Again, at the bottom of the pop up, they'll be an option to select an existing library.
Strength and Honour (2025)
zuimeng
:D
Thanks!
