Author Topic: Crossfade Glitch  (Read 1430 times)
Stein
Hi. I'm a long time user of Musicbee for about 10 years and love it. Since I purchased a new computer a year ago (quite a high spec) when I select a new track while one is still playing it only crossfades sucessfully every other time or so. I do run Musicbee on 2 other lower spec pc's and it always crossfades perfectly on those.  The preferences are identical on the three machines:- Crossfade 8 seconds and Fade in 2 seconds and crossfade when skipping tracks is checked.
The music files and library are on a Synology NAS. I only run 1 instance of Musicbee at a time and everything else works fine. I can't find a reason for crossfade not working consistantly on the fast machine. Any ideas?
Cheers
I don't think this should have been raised here as a bug report, so addressing it as a question:
You could check some things such as:
- Windows' audio settings
- soundcard drivers and settings (on-board audio or external dac?)
- advanced MusicBee's player settings
Thread moved to Questions
