Hello everyone. First time posting here.
I cannot use any equalizer presets for some reason. Even the experimental ones I've created to see if they're available. They simply do not appear in the settings window.
I've even checked my equalizer folder, and found all the .sde files. Including the ones I've created to test them out.
In the screenshot, you will find my Equalizer's Preset bar on the left. On the right is my folder containing all the .sde files; (C:\Program Files (x86)\MusicBee\Equaliser) .
I've tried uninstalling and re-installing Music Bee, yet nothing's worked. It really bothers me since I'm an avid equaliser user
UPDATE: I just solved it. The equalizer is finally working.
Previous times, when I tried reinstalling the Installer version, I hadn't deleted the remaining folder named MusicBee in my ProgramFiles(x86) folder after the uninstallation. But now, I deleted the folder after uninstalling it from the Control Panel. Then I installed it again (using a yet another downloaded .zip from the website). I was pleasantly surprised when I found the playlists I had created, along with all the interface changes I've made.
If it's of any importance, the only file/folder remaining in the MusicBee folder after uninstalling it were:
-bass_alac.dll
and
-Equaliser (folder)
Thank you all for the quick feedback!
