Author Topic: MusicBee functions for virtual tags cheatsheet  (Read 12591 times)
but $eq ,$le, $gt, etc?
Will do, as promised.
But it takes a clear mind to edit a BBCode formatted post like this one. (which I currently don't have ;-)
It's too easy to destroy the layout of a post like this one.
i've done it for you:
$eq(number1,number2): compares 2 integer or fractional numbers, determines if number1 is equal to number2, e.g. $eq(1.0,1) returns "T"
$ne(number1,number2): determines if number1 is not equal to number2
$gt(number1,number2): determines if number1 is greater than number2
$lt(number1,number2): determines if number1 is less than to number2
$ge(number1,number2): determines if number1 is greater than or equal to to number2
$le(number1,number2): determines if number1 is less than or equal to number2
$eq(number1,number2): compares 2 integer or fractional numbers, determines if number1 is [i][b]eq[/b][/i]ual to number2, e.g. $eq(1.0,1) returns "T"
$ne(number1,number2): determines if number1 is [i][b]n[/b][/i]ot [i][b]e[/b][/i]qual to number2
$gt(number1,number2): determines if number1 is [i][b]g[/b][/i]reater [i][b]t[/b][/i]han number2
$lt(number1,number2): determines if number1 is [i][b]l[/b][/i]ess [i][b]t[/b][/i]han to number2
$ge(number1,number2): determines if number1 is [i][b]g[/b][/i]reater than or [i][b]e[/b][/i]qual to to number2
$le(number1,number2): determines if number1 is [i][b]l[/b][/i]ess than or [i][b]e[/b][/i]qual to number2
Thanks a lot. I will update and integrate it later today.
But it's this kind of BBCode formatting I am talking about:
updated
- new AT&RT functions were added ($eq, $ne, $gt, $lt, $ge, $le)
- virtual tag formatting (markup) functions were added
karbock
Thanks for the [anchor] codes!
Patient work at its best!
Well observed karbock ;-)
Once I discovered that this could be done (and how), this seemed the post that would benefit the most from it.
(It was just a pity it happens to have some 70 candidates for anchors ;-)
edit
Also it's a bit ridiculous, the BBcode post design now has some 16.500 characters for a post that contains some 460 words ;-)
(BBCeditor is huffing and puffing on it, icecaps melting)
Last Edit: February 20, 2023, 07:01:25 AM by hiccup
