Author Topic: Songs listed 4 times in albums  (Read 2003 times)
Tim Griffith
I am new to MusicBee and I just installed it. When I created my music list it shows the music that I did not rip through ITunes 4 times. If I just use my ITunes library then it shows just 1 song. I have tried uninstalling it and just picking one library and if it was not done through Itunes then it shows each song 4 times. I did look for cue files and there is none that I can find. Thank you
If you right click/ Edit one of the tracks, are the others automatically selected?
If not, have a look at the Properties tab in the tag editor to see the file path MB found each of the tracks
Tim Griffith
Thank you, some how I duplicates in 4 different directories in the same main folder.
