Author Topic: Dark skin with Player Centered (and Left) (Resource included)  (Read 12467 times)
mvana
Dark skin with player controls centered and another with player on the left, and a skin for Theater Embedded mode for the Now Playing tab.
2 Colors, 3 Skins : Lime Green and Windows Blue
Download page for the theme. Any feedback, help is very much appreciated.
Instructions:
Install skin ( .xmlc file):
View > Skins > Add Skin > Choose the xmlc files
Or you can simply put the skins into:
C:\Users\%username%\AppData\Roaming\MusicBee\Skins
Important: For the Skin with Centered Player Buttons:
Keep the Album Cover enabled in the main player, since the player buttons and progress bar position is depended on it to stay centered.
To enable main player auto-color:
Right Click over the Main Player > Panel Layout > Auto-Pick Panel Colors
To customize the track details you want to show on the bottom left corner:
1. Select default MusicBee 3 theme (because some theme can disable this customization feature)
2. Right Click over Main Player
3. Panel Layout > Customize... > Create desired settings.
If you want, you can install the font Outfit and enable it from:
Edit > Edit Preferences > Layout - choose Fonts here.
To get your NOW PLAYING tab similar as the screenshots attached:
1. Put the " SLICK View.xml " into
C:\Program Files (x86)\MusicBee\Plugins\TheaterMode.Embeded\
2. Restart MusicBee
4. Click > Configure Layout Icon > Main Panel > Theater Mode > SLICK View
Last Edit: February 08, 2023, 02:52:23 AM by mvana
Roby
buiibuii
im trying to set up the theater mode and it bugging out i probably set it up wrong
Step Bro
https://imgur.com/a/Lsz8rHW
Idk why the player looks that way...I've a portable installation and I've enabled both Player Centered Blue and SLICK view (yes it's in the embedded folder)
  • Heal The World
You are activating the theater mode from the wrong place.
You need to do the last step in the Now Playing tab.
@mvana...It's probably best that you mention that somewhere in the instructions, since it may not be so obvious to new MusicBee users.
Step Bro
yo thanks a lot mate
mvana
I've added the keyword "Now Playing tab".
Thanks for helping out
Last Edit: September 26, 2022, 06:41:46 AM by mvana
Muhammad
I don't know what i'm doing wrong but i cant hide the right sidebar and the artist name below is being cutoff.
https://drive.google.com/file/d/1JMSzckPcatAIBYUtNo1YoI0Gz0QxJkSO/view?usp=sharing
Last Edit: October 02, 2022, 01:58:50 PM by Muhammad
mvana
Click on the "Configure Layout" icon on the top left on the screen (beside the search bar). Then click > Right Sidebar > Hide Panel
The embedded skin is outdated, you'll need this one: https://getmusicbee.com/addons/theater-mode/356/album-art-with-playlist-and-lyrics/
