Author Topic: Dark skin with Player Centered (and Left) (Resource included)  (Read 9048 times)
mvana
Dark skin with player controls centered and another with player on the left, and a skin for Theater Embedded mode for the Now Playing tab.
2 Colors, 3 Skins : Lime Green and Windows Blue
Download page for the theme. Any feedback, help is very much appreciated.
Instructions:
Install skin ( .xmlc file):
View > Skins > Add Skin > Choose the xmlc files
Or you can simply put the skins into:
C:\Users\%username%\AppData\Roaming\MusicBee\Skins
Important: For the Skin with Centered Player Buttons:
Keep the Album Cover enabled in the main player, since the player buttons and progress bar position is depended on it to stay centered.
To enable main player auto-color:
Right Click over the Main Player > Panel Layout > Auto-Pick Panel Colors
To customize the track details you want to show on the bottom left corner:
1. Select default MusicBee 3 theme (because some theme can disable this customization feature)
2. Right Click over Main Player
3. Panel Layout > Customize... > Create desired settings.
If you want, you can install the font Outfit and enable it from:
Edit > Edit Preferences > Layout - choose Fonts here.
To get your NOW PLAYING tab similar as the screenshots attached:
1. Put the " SLICK View.xml " into
C:\Program Files (x86)\MusicBee\Plugins\TheaterMode.Embeded\
2. Restart MusicBee
4. Click > Configure Layout Icon > Main Panel > Theater Mode > SLICK View
Last Edit: February 08, 2023, 02:52:23 AM by mvana
Roby
buiibuii
im trying to set up the theater mode and it bugging out i probably set it up wrong
Step Bro
https://imgur.com/a/Lsz8rHW
Idk why the player looks that way...I've a portable installation and I've enabled both Player Centered Blue and SLICK view (yes it's in the embedded folder)
You are activating the theater mode from the wrong place.
You need to do the last step in the Now Playing tab.
@mvana...It's probably best that you mention that somewhere in the instructions, since it may not be so obvious to new MusicBee users.
Step Bro
yo thanks a lot mate
mvana
I've added the keyword "Now Playing tab".
Thanks for helping out
Last Edit: September 26, 2022, 06:41:46 AM by mvana
Muhammad
I don't know what i'm doing wrong but i cant hide the right sidebar and the artist name below is being cutoff.
https://drive.google.com/file/d/1JMSzckPcatAIBYUtNo1YoI0Gz0QxJkSO/view?usp=sharing
Last Edit: October 02, 2022, 01:58:50 PM by Muhammad
mvana
Click on the "Configure Layout" icon on the top left on the screen (beside the search bar). Then click > Right Sidebar > Hide Panel
The embedded skin is outdated, you'll need this one: https://getmusicbee.com/addons/theater-mode/356/album-art-with-playlist-and-lyrics/
