Author Topic: Bugged lengths with new downloaded album  (Read 1670 times)
NeroMegadeth
As you can see in the photo, the lengths of the songs are bugged/don't show the real length. This has only happened with this new added album, as the rest show the real lengths.
Do the files play? And if so, for the correct length of time?
What format are the music files?
Were the files ripped from a CD?
NeroMegadeth
1. 3.3.7367
2. Installer
3. Yes and yes
4. .mp3
5. No
  • Heal The World
I had something similar happen some time ago (some of the song durations were doubled)
I don't even know when it started because I only discovered it late last month. It may well be that it was always like this ever since I switched to MB Portable.
But anyway, a file rescan for each of them had solved the problem. So try that and see if it helps.
Screenshot is from the 4th of October last month
You're using a rather old version. I suggest updating to the latest version (3.4.x) from the downloads page and then applying the latest patch which is available from the signature below.
After updating, select the files that are showing incorrect lengths and rescan the files:  right-click > send to > file rescan.
If the time still isn't correct, download and run MP3Val and/or MP3Diags to see if the files are corrupt.
