Author Topic: Dark bitmap skin (old version)  (Read 16304 times)
mvana
A simple dark bitmap based theme for MusicBee 3.0+ with 2 versions, with and without auto color for main player.
Any help, suggestions to improve the theme is much appreciated.
In the downloaded file you'll find the images, xml template, etc. to modify the theme.
Thanks to hiccup, Steven and others for the support
Download Page for the theme
Version 1.01:
Fixed typo
Improved colors for sidebar controls
Changed Hover icons for auto color theme
Version 1.02:
Color improvement
Better icons
Improved Progress bar
Last Edit: December 09, 2021, 03:53:46 AM by mvana
  • MB Version: 3.6.8878 P
Nice work. Looks very good.
There is a typo in the BitmapTheme.xml at line 232.
<element id="PlayerFlat.ProgressButton" fg="Highligh2t" />
And I find the sidebar player controls hard to see.
mvana
Thank you very much! I just updated the theme. Sidebar control colors are improved
Last Edit: November 26, 2021, 08:37:18 AM by mvana
Thank you for the change
1.
It's not necessary to have (and maintain) two different versions of your skin for auto-coloured and not auto-coloured versions.
If you have set PlayerAutoColor to 'true', then a user can decide for himself to use auto-colouring or not.
2.
If the player panel is set to display 'rating' but not 'loved', the rating stars get bumped into undesired territory.
(check the 'replacementElement id' elements at the bottom of your skin.xml file to make the necessary adjustments)
mvana
1.
2.
Thanks for the help, it's fixed now.
I separated the theme with auto-color because of different icons. Mouse hovering works much better in the auto color version.
Some other things you may want to take a look at:
(difficult to see icons, 'search' for playing tracks unreadable, gradient background for the Spectrum Visualiser, a bit hard and inconsistent green/blue colour for Spectrum Visualisations.
mvana
Spectrum colors has been fixed.
I was trying to change the png elements for the hard to see icons, which are somehow turning into black, couldn't figure out what's causing that. Do I have to create image for all of them?
Which codes controls the Playing Tracks search colors?
And while trying to repositioning the player panel Spectrum Visualizer, I was using
<element id="Spectrum"
but resulting in errors.
Last Edit: November 27, 2021, 09:26:16 PM by mvana
The Sample Skin should be helpful to find the concerning elements.
https://getmusicbee.com/forum/index.php?topic=22300.msg130967#msg130967
mvana
What doe these do? I can't find any changes no matter the values?
<element id="Controls.SearchBoxPTop.Default" bg="254,250,238" fg="191,52,7" />
<element id="Controls.SearchBoxPTop.NotActivated" bg="252,244,215" bg2="252,244,215" bdr="154,182,218" />
https://getmusicbee.com/forum/index.php?topic=2499.msg108200#msg108200
(Ptop = when the player panel is positioned at the top)
mvana
Thanks, that's very helpful.
How to change the color of the "Arrange Panel Layout" icon? I've tried changing the image, icon color override, but still it's black no matter what...
(updated theme with better colors and icons)
Last Edit: November 28, 2021, 12:52:30 PM by mvana
The Incredible Boom Boom
From my skin files...
<!-- Fully Compressed Caption Bar, L/R arrow buttons + Layout Icon -->
<element id="CaptionBar.HeaderControl.Default" fg="highlighted" />
<element id="CaptionBar.HeaderControl.Disabled" fg="highlighted" />
<!-- Tabs Bar, below Caption Bar: L/R arrow + Layout Buttons -->
<element id="Panel.HeaderButtonOverride.Default" fg="highlighted" /> <!-- 40,106,144 50,112,144 --> <!-- Highlights L/R buttons in Music Explorer and Layout Button everywhere... keep 'highlighted' -->
<element id="Panel.HeaderButtonOverride.Disabled" fg="white" />
<element id="Panel.HeaderButtonOverride.Highlight" bg="highlighted" fg="255,0,0" />
mvana
Thank you, I've just tried it, still not working. I've changed the png for PanelLayout icon. It's still black, when mouse hovering it changes color.
Which code is controlling the colors of PanelLayout icon?
The elements above do, so another element somewhere in your skin must be overriding the default color.
Search your skin file for "Override." If you don't have any of those elements, you'll probably need to search "CaptionBar" line-by-line and change any element that looks like a match to a stand-out color.
