Author Topic: How to enable auto-pick panel colors if it's greyed out? (SOLVED)  (Read 2544 times)
mvana
I want the current playing track's album art blurred as the background in the main player. But the "auto-pick panel colors" is greyed out. How can I enable it?
Thanks in advance!
Solution:
Bitmap Skins (.xmlc) can lock the ability to auto pick colors.
Last Edit: December 01, 2021, 04:06:24 PM by mvana
it needs to be supported by the skin. I think the dark-fine tuned skins support it
mvana
Thank you, it works!
