Author Topic: View Play History and Recently Added  (Read 3354 times)
Peet
I'm pretty sure I was able to view Recently Added Tracks in the left hand panel.  It seems to have disappeared.  How can I get it back?
For recently added:
Create an auto-playlist where the criteria is
Date Added / is in the last / [select your desired time frame]
For recently played:
Last Played / is in the last / [select your desired time frame]
That appears (appeared?) by default just under the "Playlists" listing along BEFORE all your custom playlists start--actually there are 3 default autoplaylists.  Be sure you have "Playlists" checked in Prefs/Layout(1).  If you have accidently deleted the autoplaylist, follow phred's instructions to recreate one.
