Author Topic: Play tracks with 0 play count only?  (Read 3716 times)
gorney
Is there a way to only play tracks that have not been played before (0 play count)?
You can set up an auto-playlist where <play count> <is less than> 1
That way every time you play a track that is in the auto-playlist, it will drop off the list.
OR
You can set up a filter with the same criteria.
Both will operate the same way.
Auto-playlists on the Wiki: https://musicbee.fandom.com/wiki/Playlists#Auto-Playlists
Filters on the Wiki: https://musicbee.fandom.com/wiki/Filters
stardepp
@gorney You just need to do the three steps:
Last Edit: November 14, 2021, 04:50:32 AM by stardepp
@stardepp- Just curious as to why you're suggesting the OP use Auto-DJ instead of a permanent auto-playlist or filter? With Auto-DJ the OP would have to set the criteria each and every time they wanted to listen to all tracks that have a zero playcount. Unless there's a way to save the Auto-DJ criteria, which I'm not sure there is.
stardepp
Thanks for your very valuable tip, I just created such a auto-playlist for myself 😎
I've been using MusicBee since 2012 and I'm still learning new things thanks to you guys here on the forum, thanks for that. 🍀
Last Edit: November 14, 2021, 01:32:35 PM by stardepp
Thanks for your very valuable tip, I just created such a auto-playlist for myself.
You're welcome. I'm glad you found that helpful.
I have been using MB since 2009 (v 0.3) and and still finding and learning new things.
stardepp
Interesting. No matter where I am, at every opportunity I tell very positive about MusicBee without being asked.
Do you know what "automatically export a static copy" should mean, see settings Automatic Playlist.
Yes. Enabling that will export a copy of the playlist, as it is at that moment, whenever new tracks are added. I'm not 100% certain but I think the export happens when MB closes. Although it may be once it notices a change. You need to set the path for exporting in Preferences > Library > playlists > exported playlists. Depending what device will be using the exported playlists, you'll need to adjust the playlist format and the other three options under that.
I use my exported playlists so that my Subsonic server can see them. Also on my Logitech Squeezeboxes.
stardepp
Thank you for your detailed explanation, yes a backup of the playlists is created, see screenshot:
Last Edit: November 14, 2021, 05:13:57 PM by stardepp
