Author Topic: Add silence between some 'albums' but not others  (Read 1877 times)
ultrarunner2018
Hello;
I have both Rock and Classical in my MusicBee library. I select the genre I want to listen to using filters.
For Rock tracks, I rarely listen to an entire album, and prefer no silence between tracks. Matter of fact I use crossfading.
However, for Classical pieces, I don't want any crossfading - and have the 'do not crossfade' option ticked for these tracks.
I also prefer to add some silence (about 5 seconds) between pieces (works).
I see there is an option in Preferences > Player to add silence to end of each track, but ticking this box would add silence to Rock tracks - which I do not want.
I could add the silence to the end of the last movement of each Classical piece manually using my DAW (Reaper) but that would be time consuming.
Any ideas?
Thanks
Ultrarunner
ultrarunner2018
Update:
I just realized that I had the option 'Remove silence at start and end of each track' ticked. I have un-ticked it. This should solve my problem, since there is normally enough silence at the end of a Classical piece as ripped from the CD.
Sometimes it's difficult to see what is and what is not ticked.
