Author Topic: Copy Text From Music Explorer Artist Profile  (Read 1809 times)
DaveOzric
Hello, I was looking up an artist and realized I could use your program to find info on them. It was better info than I could find on Google but can't highlight or copy paste the text. Is there a way to view the source of this or enable the text to be copied?
Thank you
DaveOzric
I just donated $20 for all the hard work, regardless of this outcome. I just wanted to say thank you.
It is sourced from LastFM
What you could do:
Create a weblink in the Track Information panel that leads to LastFM's artist biography page. Then you can easily select and copy what you want.
And/or enable MusicBee's Artist Biography panel. If you right-click that, you have the option 'Copy Biography'.
DaveOzric
Cool, I will add the link and do it that way. I just could not find the same info, but yes Last FM is the source.
Thanks
