Author Topic: Having to constantly install musicbee portable  (Read 1736 times)
aleckbut.org
I have installed musicbee portable on an external hard drive but every time I go open musicbee it wants me to reinstall it. What am I missing?
Do you disconnect the hard drive between listening sessions?
Do you shut down your PC between listening sessions?
aleckbut.org
Yes all around. I'm trying to start a digital library for our community radio station so I wanted something I could add music to on my computer and then take to the  station for the DJs to use. Am I going to have to go through the install process every time as a result?
I'm also having a problem where I'll add music on my computer to files on the external and then add them to the musicbee library. Then when I plug the external into the DJ computer, the music isn't in the library anymore even though I can still see the files in the folder.
After you have installed the portable version, what is the filename that you use to open MusicBee?
Is it MusicBeePortable_3_4.exe or MusicBee.exe ?
