Author Topic: Missing tags after relinking paths-SOLVED  (Read 1238 times)
LtTawnyMadison
There are some songs MB couldn't find the files for in my playlists. After doing "Relink Music File Paths," the songs were found, but without their tags--except in the Title tag, their names were changed to be the same as the filenames. And I can't find a way to revert the relinking action and instead use "locate missing files" which only works for me doing one song at a time. Is there a batch way or somewhat easy way to fix/find the missing tags? I'm pretty sure all my songs have embedded tags from before using MB.
UPDATE -- I guess I just needed to wait a few minutes. They suddenly all showed their tags!
Last Edit: November 08, 2021, 10:09:50 PM by LtTawnyMadison
